| Message |
Losing coolant, but I passed the block tester. I don't see any leaks at hoses to radiator or to overflow tank. Water pump looks dry. Thermostat is working. Have replaced radiator and fan clutch. I am seeing a ton of coolant on the inside drivers wheel but I can't tell if that is from the overflow tank boiling over, or if there may be some tube leaking there. Any ideas? Thanks for any guidance.
"Yeah, it can break the tires loose." |
